This example describes FA configuration and behavior in a dual-homed SMLT deployment.
The following figure shows a simple FA solution in a dual-homed SMLT deployment. In this deployment, a pair of BEB switches (BEB A and BEB B) operating as IST peers are configured as the FA Server. An access switch or a wiring closet switch, configured as an FA Proxy, connects to the FA Server.
The FA Proxy advertises I-SID-to-VLAN assignment mappings to the FA Server. Both BEB switches receive the mapping information using LLDP PDUs containing assignment TLVs. The switch that learns the mapping first considers the I-SID to be discovered locally and creates the I-SID on its device. The mapping information is then shared with its IST peer switch. When the peer switch receives the mapping across IST in a new SMLT message, it too creates the I-SID on its device. This I-SID however, is considered to be discovered remotely because it is learnt from synchronization with the peer switch. The mappings can also be learned on the FA Server from both LLDP PDUs and from IST synchronization.
FA configuration in dual-homed SMLT
A pair of BEB switches operating as IST peers are configured as the FA Server. An access switch or a wiring closet switch, configured as an FA Proxy, connects to the FA Server.
Ensure that the proxy device (for example, an access switch) is properly configured for FA. See the corresponding product documentation for information on how to configure FA on the switch.
  1. Configure SMLT and vIST on switches BEB A and BEB B.
    Caution
    Caution
    For the IST peer switches acting as the FA Server to transmit the same FA System ID (based on the virtual MAC), SMLT configuration on both the switches must be the same.
    For detailed information on configuring SMLT and vIST, see MultiLink Trunking and Split MultiLink Trunking.
Configure BEB A and BEB B as the FA Server:
Perform the following configuration on each switch.
    enable
    configure terminal
  2. Enable FA globally:
    fa enable
  3. Enter MLT interface configuration mode:
    interface mlt <1–512>
  4. Enable FA on the MLT:
    fa enable
    Enabling FA automatically enables message authentication. Also, the authentication key is set to the default value and the system displays the encrypted authentication key on the output.
  5. Optional: Configure an FA authentication key with a value different from that of the default value:
    fa authentication-key [WORD<0-32>]
    Caution
    Caution
    When you configure the FA authentication key, you must configure the same value on both BEB switches in the SMLT.
Verify global and MLT-level FA configuration on BEB A and BEB B:
  1. Verify global configuration of FA using one of the following commands:
    • show fa
    • show fa agent
  2. Verify MLT-level (interface-level) configuration of FA:
    show fa interface
Verify FA discovery on BEB A and BEB B:
  1. Verify discovery of the FA Proxy.
    show fa elements
View FA I-SID-to-VLAN assignments on BEB A and BEB B:
  1. View the FA I-SID-to-VLAN assignments:
    show fa assignment
    To view FA I-SID-to-VLAN assignments on specific ports, enter:
    show fa assignment {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Verify creation of Switched UNI I-SIDs on BEB A and BEB B:
  1. Verify creation of Switched UNI (ELAN) I-SIDs:
    • View ELAN I-SID information using show i-sid elan.
    • View ELAN I-SID information on a specific MLT using show mlt i-sid [<1–512>].
      Viewing ELAN I-SID information on an MLT is very useful to understand the origin of the I-SID, when multiple client or proxy devices connecting to the FA Server using SMLT MLT advertise the same I-SID-to-VLAN mappings. In the event of a link failure on an MLT, the origin of the I-SID helps determine on which MLT, and thereby from which proxy or client device, the mappings were successfully learnt.
SMLT configuration on BEB A and BEB B
Perform the same configuration on both BEB A and BEB B:
Switch:1>enable
Switch:1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#interface mlt 1
Switch:1(config)#smlt
vIST configuration on BEB A and BEB B
On BEB A:
Switch:1(config)#vlan create 2261 type port-mstprstp 0
Switch:1(config)#vlan i-sid 2261 1502261
Switch:1(config)#interface vlan 2261
Switch:1(config)#ip address 192.0.2.0 255.255.255.0 2
Configure BEB B (IP address 192.0.2.1) as the IST peer.
Switch:1(config)#virtual-ist peer-ip 192.0.2.1 vlan 2261
On BEB B:
Switch:1(config)#ip address 192.0.2.1 255.255.255.0 2
Configure BEB A (IP address 192.0.2.1) as the IST peer.
Enable FA globally and on the MLT:
Switch:1(config)#fa enable
Switch:1>show fa
                          Fabric Attach Configuration
                            FA Service : enabled
                       FA Element Type : server
                 FA Assignment Timeout : 240
                  FA Discovery Timeout : 240
                     FA Provision Mode : spbm
Optionally, configure an FA authentication key with the value dual-homed-smlt. Ensure that you configure the same value on both switches BEB A and BEB B.
Switch:1(config-mlt)#fa authentication-key dual-homed-smlt
Switch:1(config-mlt)#fa enable
Switch:1(config-mlt)#exit
Switch:1(config)#show fa interface
                            Fabric Attach Interfaces
INTERFACE    SERVER   MGMT     MGMT     MSG AUTH MSG AUTH    ORIGIN
             STATUS   ISID     CVID     STATUS   KEY
Mlt1         enabled  0        0        enabled  ****
 1 out of 1 Total Num of fabric attach interfaces displayed
Verify discovery of the FA Proxy:
Switch:1(config)#show fa elements
                        Fabric Attach Discovery Elements
                         MGMT                                         ELEM ASGN
PORT   TYPE              VLAN STATE  SYSTEM ID                        AUTH AUTH
1/21   proxy             2    T / S  10:cd:ae:09:40:00:20:00:00:01    AP   AP
1/22   proxy             2    T / S  10:cd:ae:09:40:00:20:00:00:01    AP   AP
1/23   proxy             2    T / S  10:cd:ae:09:40:00:20:00:00:01    AP   AP
                      Fabric Attach Authentication Detail
       ELEM OPER                      ASGN OPER
PORT   AUTH STATUS                    AUTH STATUS
1/21   successAuth                    successAuth
1/22   successAuth                    successAuth
1/23   successAuth                    successAuth
State Legend: (Tagging/AutoConfig)
T= Tagged,    U= Untagged,    D= Disabled,    S= Spbm,    V= Vlan,    I= Invalid
Auth Legend:
AP= Authentication Pass,  AF= Authentication Fail,
NA= Not Authenticated,  N= None
3 out of 3 Total Num of fabric attach discovery elements displayed
The FA Proxy advertises I-SID-to-VLAN assignment mappings to BEB A, on MLT ports 1/21 to 1/23. View the FA I-SID-to-VLAN assignments on BEB-A:
All ports in the MLT receive the FA assignment mappings, as shown in the following output.
Switch:1(config)#show fa assignment
            Fabric Attach Assignment Map
Interface  I-SID      Vlan       State      Origin
1/21       2          2          active     proxy
1/21       3          3          active     proxy
1/21       4          4          active     proxy
1/22       2          2          active     proxy
1/22       3          3          active     proxy
1/22       4          4          active     proxy
1/23       2          2          active     proxy
1/23       3          3          active     proxy
1/23       4          4          active     proxy
FA configuration on BEB B
Configure the FA authentication key dual-homed-smlt. Ensure that you configure the same value as on BEB A.
Verify discovery of FA Proxy:
                         MGMT                                         ELEM ASGN
1/17   proxy             2    T / S  10:cd:ae:09:40:00:20:00:00:01    AP   AP
1/18   proxy             2    T / S  10:cd:ae:09:40:00:20:00:00:01    AP   AP
1/19   proxy             2    T / S  10:cd:ae:09:40:00:20:00:00:01    AP   AP
1/20   proxy             2    T / S  10:cd:ae:09:40:00:20:00:00:01    AP   AP
       ELEM OPER                      ASGN OPER
1/17   successAuth                    successAuth
1/18   successAuth                    successAuth
1/19   successAuth                    successAuth
1/20   successAuth                    successAuth
Auth Legend:
4 out of 4 Total Num of fabric attach discovery elements displayed
The FA Proxy device advertises I-SID-to-VLAN assignment mapping requests to BEB B on MLT ports 1/17 to 1/20.
View FA I-SID-to-VLAN assignments on BEB-B:
Switch:1(config)#show fa assignment 1/17
1/17       2          2          active     proxy
1/17       3          3          active     proxy
1/17       4          4          active     proxy
Verify the creation of FA Switched UNI (ELAN) I-SIDs on BEB A and BEB B.
On BEB A:
Switch:1(config)#show i-sid elan
                                        Isid Info
ISID   ISID                    PORT               MLT          ORIGIN            ISID
ID     TYPE       VLANID       INTERFACES         INTERFACES                     NAME
2     ELAN       N/A          -                  c2:1         -  ---  -  -lr  -   ISID-2
3     ELAN       N/A          -                  c3:1         -  ---  -  -lr  -   ISID-3
4     ELAN       N/A          -                  c4:1         -  ---  -  -lr  -   ISID-4
ORIGIN Legend:
C: manually configured; D: discovered by FA or EPT
M: FA management; E: discovered by EAP; A: auto-sense
l: discover by local switch  r: discover by remote VIST switch
8k_fanout:1(config-if)#shlw mlt i-sid
View the I-SID information for MLT 1 on BEB A.
Switch:1(config)#show mlt i-sid 1
                                 MLT Isid Info
              ISID                   ISID
MLTID IFINDEX ID       VLANID C-VID  TYPE     ORIGIN              ISID     BPDU
        NAME
1     6144    2        N/A    2      ELAN     -  ---  -  -lr  -   ISID-2
1     6144    3        N/A    3      ELAN     -  ---  -  -lr  -   ISID-3
1     6144    4        N/A    4      ELAN     -  ---  -  -lr  -   ISID-4
3 out of 3 Total Num of i-sid endpoints displayed
ORIGIN Legend:
On BEB B:
                                        Isid Info
ORIGIN Legend:
View the I-SID information for MLT 1 on BEB B.
                                 MLT Isid Info
              ISID                   ISID
                                                               NAME
ORIGIN Legend:
The following section describes the behavior if, for example, a link failure occurs between the FA Proxy and BEB B, as shown in the following figure.
FA behavior in dual-homed SMLT during a link failure
A pair of BEB switches operating as IST peers are configured as the FA Server. An access switch or a wiring closet switch, configured as an FA Proxy, connects to the FA Server. The link between the proxy and BEB B has failed.
View the I-SID-to-VLAN assignments on BEB A:
Switch:1(config)#show fa assignment 1/21
View the Switched UNI (ELAN) I-SIDs created on BEB A.
                                        Isid Info
2      ELAN       N/A          -                  c2:1         -  ---  -  -l-  -  ISID-2
3      ELAN       N/A          -                  c3:1         -  ---  -  -l-  -  ISID-3
4      ELAN       N/A          -                  c4:1         -  ---  -  -l-  -  ISID-4
ORIGIN Legend:
                                 MLT Isid Info
              ISID                   ISID
                                                              NAME
1     6144    2        N/A    2      ELAN  -  ---  -  -l-  -  ISID-2
1     6144    3        N/A    3      ELAN  -  ---  -  -l-  -  ISID-3
1     6144    4        N/A    4      ELAN  -  ---  -  -l-  -  ISID-4
ORIGIN Legend:
View the Switched UNI (ELAN) I-SIDs created on BEB B.
BEB-B:1(config-mlt)#show i-sid elan
                                        Isid Info
2      ELAN       N/A          -                  c2:1         -  ---  -  --r  - ISID-2
3      ELAN       N/A          -                  c3:1         -  ---  -  --r  - ISID-3
4      ELAN       N/A          -                  c4:1         -  ---  -  --r  - ISID-4
ORIGIN Legend:
                                 MLT Isid Info
              ISID                   ISID
        NAME
1     6144    2        N/A    2      ELAN     -  ---  -  --r  -    ISID-2
1     6144    3        N/A    3      ELAN     -  ---  -  --r  -    ISID-3
1     6144    4        N/A    4      ELAN     -  ---  -  --r  -    ISID-4
ORIGIN Legend:
